carinatauk
This thread has some good pointers:
http://www.ukgser.com/forums/showthread.php?t=83335&highlight=tools+trip
I take:
On-bike toolkit with added needle nose pliers and small adjustable. Into the little spaces in the tool tray I have electrical tape, lengths of wire, a couple of junior hacksaw blades and a little led continuity tester.
In my little 'Vern' topbox, I have:
Little first aid set.
Rolled up 'Platypus' water carrier
Two disposable lighters
Bulb set
Alternator belt
Throttle cable
Clutch cable
Clutch release arm and pivot bolt (used)
Clutch lever (used)
Brake lever (used)
Stubby No2 Philips screwdriver
Oil sight glass
Cut down nearside pillion footrest hanger (used)
Hall sensor (used, known working)
Araldite Rapid and cotton wool make-up cleaning pads
1m length of fuel injection hose and clips
Cable ties
1/2 litre sigg bottle full of oil with 3m of duct tape wrapped round it
Cut down little funnel for topping up the oil (does my head in pouring it all over the rocker cover)
Final drive big bearing and seal
Puncture repair kit
(sounds lots but most of it is light weight and it doesn't even half fill the little top box - gets 'edited' for short trips)
Contained in a small padded bag, in a pannier I have:
A little 3/8" Teng socket set with an extra (14mm? - can't remember but it's the right one) socket for the crankshaft pulley.
10mm spanner
13mm spanner
Pair of quality pliers
Small, quality mole grips
Universal jubilee clip making set
Set of quality long shaft allen keys
Set of torx bits (not many torx fasteners on my 1100)
Gas powered soldering iron and solder
Small edge cutters
Little tyre compressor
Other lengths of wire and cable ties etc in a little package, elastic banded to the battery.
I always have a Leatherman Wave and a Petzl led headtorch in my jacket pocket and breakdown cards etc in my wallet.
Obviously this is all for a long trip - if it was a few days in the UK, I'd take much less and resign myself to calling a breakdown service and getting trailered home if something not worth fixing (like the FD bearing) went.
Feck me
What do you call a long trip; some folks take less than this on a RTW
What about clothes, kitchen sink etc? will they fit
