Tour of Berkshire Fords - Recce
I found my way around to the other end of it. That marker post says 4 feet deep and I suspect it's correct :)
Ah well, a job for another day.
I used that ford one January when I was test driving the new Range Rover. The salesman was new and lived in Maidenhead, so didn't know the area. ;) As we went in to the water I said "Is that marker board in feet or metres?" He went pale.
Good reason for maintaining a constant speed through water - if you go fast the water washes over the windscreen and you can't see the exit!
:hapybnce:
Clive, I have had a dig through my old TBMs issue 26 is the one you need if you can get hold of a copy. it has a rough guide to Berkshire. it is a good route but some of it might not suite the GS. especially the railway crossing:eek:
Anyway, on OS sheet 175just south of Farley Hill is the ford I mentioned it is at 753 636 but not marked as a ford!
the route in TBM takes you through a concrete based ford at 743 636 in a northerly direction then 200m turn right, follow this lane turn sharp left up a hill to a tarmac road, turn right then right again follow this lane to a T turn right this leads to a much deeper rocky ford, you cannot see the exit but if you follow the river the exit will appear, once across turn right at the next T junction and you will return to the first ford.
you can do this loop on green lanes or tarmac, it is obvious on the map.
have fun:D
have fun:D
743 636 is the one I have photographed above - the 200m turn right is the byway I came down to the ford (also photo above) - the rest I can see on the map - I may need to wait until the current floods subsides a bit, unless I can bodge a good snorkel for the 1200 :)
Thanks for the info.
Actually, I've just noticed there is a ford marked at the "New Mill", Eversley
I remember getting married there, but I don't remember the ford. Must have been too p*ssed ;)
I was married there as well, excellent place, but my interest lies more in the food, which was very good indeed, rather than in booze. I am given to understand that the booze is of a standard to match the food - my brother is an experienced drinker.
If you carry straight on past the entrance to the New Mill you will find the ford ion a few yards. Ford is quite a good depth even in dry weather, mainly due to the fact that the blackwater is fed by lots of sewage works. Not one to fall in at.
Excellent stuff Clive :thumb, I'm ex of Reading (Newport Rd, just around the corner from Caversham bridge) and I still return from time to time to visit my Grand-Mother, Uncles and Aunts etc. who funnilly enough all live around Tilehurst and Calcot now.
It's definately wetted my appitite seeing those pics, though whether I'd have the bottle to ride through them on a fully freighted 1150 Adv, that I can only tip-toe with is another matter :yikes !
Part 2 - 21st August 2004
Just got back from a further tour - mainly I was looking for some fords I didn't find the last time.
The first one at Stanford Dingley is reached via a RUPP which is the other side of an unlocked gate.
I didn't like the look of this to start with - a steep grassy entry - as I suspected I had some trouble getting back out again.
The ford - approx 4 inches deep, gravel bottom - tricky to get into/back out of with a heavy 1200GS on damp grass :)
I didn't like the look of the continuation of the path the other side of the ford, so returned the way I came. I managed to find where this RUPP came out - it had a further gate restricting access and a Voluntary Restriction notice from LARA
A view of the same ford from the other side
The second Bucklebury ford - a pair of fords each side of a footbridge - forms the start of a short byway between the roads running each side of the river Pang.
This is the steep 4 foot entry point on the left
The right hand side - both fords are approx 4 inches deep with gravel bottom.
The same ford looking across to the road (the way I went back)
This is a tiny ford I found in Burghfield Common after a tip-off from shugie - 2 inches deep over concrete/tarmac
As the rain was holding off I thought I would try a few more of the Byways around Carters Hill - this one started off gravel and got progressively worse.
Just along from here someone had disguised a 2 foot deep "trench" as a shallow wide puddle.
