Tourance tyre pressures???
  • Thread starter Thread starter Bagpuss
Bagpuss
Hi,
Just swapped my TKC's for Tourance's and was wondering what the best tyre pressures were in other peoples experience???
As an aside, I thought my bike was riding a bit funny the other day, which seemed even harsher once I changed to Tourance's.... check rear pre-load dial and some toe rag had wound it right out... maybe explains why it was like a bucking bronco??
15 1/2 stone :rolleyes:, should pre-load be at standard setting? :eek:
I'm running 36 front and 42 rear but I do carry a bit of kit around with me.
I used to alter the pressure for two up, etc, then was told to run them on 35/42 all the time, as this is what Tourance say, no problems, feel good!
Bagpuss said:
Hi,
I'm 16st (ahem, it's all muscle, naturally).
Tourances 34/40 with preload about 10%-15% from max. A "firm" ride sir, but stable and planted. Just had the tyres fitted and the front was blown to 40psi. Veeeerrry unstable until I realised that it wasn't fork brace/puncture/discs falling off.
