tadhgocuilleain
I fitted Touratech spoilers to the hand protectors on my R1150GS Adventure on Friday evening and went for a ride yesterday. I immediately noticed that I can feel the engine vibrations a lot more through the handle bars. I ignored it for a while, but it gets very tiring. If I clutch and let the revs drop, it disappears, so it's definitely engine vibrations, rather than wind on the spoilers. I stopped, took them off and threw them into the top box and the vibrations disappeared. I'm assuming that the spoilers have changed the fundamental frequency of the bars or hand protectors, which is causing them to resonate at engine revs (particularly around 3.5k rpm). Has anyone else had this? I could add a small bit of weight to them to stop them resonating, but if it's not usual, I might try to get them exchange for a set that will hopefully have a slightly different weight.
