Seat has been well used on an airhead GSPD and shows some wear and tear, but no sagging foam. That said, with a bit of tidying up, possibly recovered, it would look fantastic. I found it a very comfortable seat but it is quite high. I have a 32” inseam and with Ohlins suspension front and rear on my GSPD I was on tiptoes. Obviously the suspension is adding an inch or two but you can get an idea. It’s basically an inch or two taller than a standard GS single seat.
Where the rack attaches to the ally frame plate ( which bolts to the subframe) there is a bolt each side. One has its correct threaded insert but the other needs a longer screw and nut as the insert is missing. No key for the lock but I’ve sourced a new lock that I think could replace it.
These were very expensive new and rarely come up for sale secondhand. Selling for £225 including tracked postage.
