Just got a set and upper body bars a bit of a faf to fit. Main thing is should fit with OE engine bars, they do, and OE lights and wont. Lamps and mount catch on bars making it impossible to get adjustment correct. Tried all sorts of variations with supplied spacers and washers but no luck. Bars do fit without lamps ok. Green circle is where I had to fit 5mm longer bolt than supplied as would only just catch on new captive bolt.
Any one fitted a set or got a solution. Just emailed Nick at TTUK see what happens.
