TPMS activator tool
er-minio
London/Rome
There are several on Amazon. Has anyone bought one and can confirm it works with the BMW sensors?
Thanks.
Got mine from Aliexpress, works well some times have to zap the sensor 2 or 3 times but great for writing codes to the ECU and just checking the tyre pressures without moving the bike.
[/IMG]
Thanks. You do activate it near the sensor and the pair the sensor with Motoscan.
Is there any indication that the sensor is awaken? Beep/sound or anything?
I use the GS911 not tried my Motoscan app for this.
If you fit a new sensor and wake it up it will remove the old code for that wheel in the ECU and automatically write the new code.
No sounds beeps etc. But you can see it happen when you view the results on the software.
Cool thanks.
I bought the same 50448 model on Amazon.
Will give it a try next week.
There is a "learning" section in Motoscan. It says to use the TPMS tool to awake the sensors.
I'm not 100% sure the sensor batteries are still working though :)
