TPMS odd behaviour
Santa-2512
Omnipotent one
North Pole
Last year i kept getting a TPMS error for low pressure on the front sensor,
Checked pressure - ok so reset with the GS 911
Fast forward to this year, ive started to notice the front Sensor reporting a pressure of 1.9 bar, the rear 2.2 as normal
Then it dropped to 1.8, so i figured something was amis
So i stuck my portable compressor on it
Sure enough 1.5 bar, so i shot it up to 2.4
disconnected it, and faffed about doing other bike shit.
Just before i replaced the valve cap, i did the old spit test, and lo and behold bubbles
AHA, so i did it again to confirm, and yes bubbles
so i stabbed the valve and let it reseal - this time no bubbles, but just in case i put the pump back on it
Again 1.5Bar, so i shot it back to 2.4
turned on, and the TPMS said 2.5 rear and 1.8 front , so i gave it a bit more - 2.5 bar showing but still only 1.9 on the kombi
Ran it to and from work to get some warmth into the tyres
The rear went up to 2.6 , but the front stays static at 1.9
MY moneys on a dying sensor, but if it is, its staying in until when i change the tyre later in the year
Have you activated the "Temp" readings on the TPMS with the GS911? Quite useful to actually see the tyre temp rise...my rear shows warmer than the front, which is understandable as it works harder. I replaced both sensors with ones from Amazon with no issues to date.
