TPS sensitivity?
PIGGLET
N Yorks/Smoggville
I've just adjusted the tps on my bike today. It's the first time I've done it and was quite surprised at how sensitive the thing is. It only took the smallest tap with very little discernable change of position to go from 0.3mv to 0.4mv.
I've set it to 0.37mv but due to it's sensitivity it doesn't seem to return to bang on o.37 every time when I open then shut the throttle, sometimes it's a wee bit higher or lower (0.01mv).
Is this normal or is it fecked :confused:
Had the same with mine but it seems to run ok :thumb2
Mick
Yup - normal. Difficult to set, you need to check AFTER the screws have been thightened 'cos it always moves a bit.
