next time use nitrogen in the tyres - that doesn't expand with heat and this whole thread might have been avoided - and you might not have fell off....
Not true...nitrogen expands with heat...believe me, for reasons that have more to do with marketing than anything else, a major tire replacement outfit here uses nitrogen to fill their tires, and I had two sets of tires from them (for two different trucks) inside of a month.
Nitrogen does expand...80 percent of compressed air is nitrogen already.... The advantages of running nitrogen include no water vapor in the tire (so you get less of a pressure change as the tires heat up and less corrosion) less oxidation of the tire rubber inside (a very questionable difference) and most of all, less likelyhood of a tire fire (no oxygen inside), which, frankly, has not been that much of a threat in my life
