Traffic Light Sensor Magnet
B Murr
Cork, Ireland
saw a bike for sale in USA with two littlew rectangular bits of metal stick to underside of centre stand. Owner told me that they were magnets and that they helped to activate the green light at some traffic lights, as most of the underroad sensors are geared to detect larger hunks of metal such as cars and that you could be a while waiting at them on a bike. He says they worked for him 75% of the time at lights that he had issues with before.
Anyone tried this or feel the need to try this? I have at times been stuck at a red light and when I suspect this sort of thing I move forward so that any car behind me can trigger the sensor.
They work really well. I can only recommend that you buy some and stick them on. Maybe buy three or four sets, tucking one pair in your underpants (where they will boost your already not inconsiderable super powers) and the rest glue to your tinfoil hat, shielding you from thought rays from the planet Zog.
I've never had the problem, but I read somewhere that if you're stuck at a red light, you can put your side stand down in the middle of the sensor and it will trigger it.
AFAIK, the underroad sensors work by induction, so the magnets should work.
:jes :jes
The problem will be knowing if you have stopped in the correct zone, you may well find yourself out of reach with the stand magnets.
I'd go for the screw fix option and you will be able to prod around a bit until you find the sweet spot, then a quick drawback on the telescopic action and you're good to go!:thumb
Or this, but the wiring may require specialist advice..........
I'm more traditional when it comes to magnets. One of these fitted to the swingarm does it for me....:thumb2
  • traditional-alnico-horseshoe-magnet-1kg-pull-75-x-39-x-8mm-pack-of-1-p695-139_image.jpg
Ive been researching this now and may put some things together for a prototype,
but 555 chips will be a big order from the fish and chip shop even on a friday.
Keep it simple and buy 15 chips them put them into 3 groups of 5 next to each other.
I dont think it matters if the chips are different sizes but they must have the same amount vinegar on each chip.
Adrian
Not sure why this straightforward question has brought out the wacky comedians, but a magnet should indeed help trigger sensors that have trouble seeing your bike - the magnet will influence the resonant frequency of the underground induction loop more strongly than non-magnetic material, and it is changes in this resonant frequency which are used to detect vehicles.
Hilltop are offering a service to smooth out the magnetic field and make pick up smoother.
I can see the attraction, although you may be poles apart from this field, unless in a state of flux.
Just announced these magnets now interface with your satnav to optimise the user experience. Generating exactly the correct stopping locating to enhance the power of these yolks. Guaranteed to change lights within 20 seconds. JJH
What happens when two awesome steeds which are both equipped with new magnetic technology arrive at the same lights at the same time but from different directions? :rob
Who will get priority :nenau
I suspect that some folk are just sitting at the lights and not aware of what is happening. I think another area where this can be useful is in dealing with barriers that can be raised, although all of the ones we have at work use an ID card to activate and there's a gap at end of pole that a bike can fit through anyway.
