You'll need to be more specific about the leak. However it is quite common for oil to leak from two places on the bevel drive, first place is the speedo sensor where an 'o' ring failure can let oil out onto the rear disc and back wheel. second place is the outer bevel drive seal, you'll know if its this one as you'll see oil running down the bevel drive...and perhaps dripping on the back wheel. Both of these are cheap and easy to fix.....unless bevel drive outer seal is leaking because of too much free play in your rear wheel bearing!!!
