Transferring Data/Disposing of old laptop
Wrinkly
beverley,england
Our old laptop will switch on and the fans start etc,but it does not boot up. Is it possible to transfer data to our new laptop.
Also what is the best way to dispose of our old laptop as the hard drive contains a lot of personal detail.
Any help or advice much appreciated.
Steve
Buy a cheap USB 2.5" HDD caddy (find out if the HDD is IDE or SATA) and stick the drive in that - then copy what you want on to another machine.
Take a hammer to the old HDD once you have everything off it.
Is the Laptop itself actually worth anything?
Al :)
Hi there.
If you are competent enough to take out a few screws try this.
Normally the bottom of a laptop has a number of panels that can be removed, for RAM memory or hopefully, the hard drive.
If so the little hard drive should be able to be pulled out, usually a plastic tag to tug it out with.
If not, perhaps when you remove the battery you will see this little tag sticking out.
Then beg borrow buy a external hard drive enclosure for a 2.5" hard drive. If this is an 'old' computer, >5 yrs the connection required is "IDE". Noted by a lot of small pins in two rows.
If not a SATA connection required - no pins sticling out of drive.
Plug in drive and attach to a computer, usually USB.
Your old hard drive will just act like a pendrive or similar just a big storage device.
Pull of your personal data onto the computer your working at by drag and frop methods.
If the laptop is 'broken'. Bin it. If drive is working ok and you've got all data off you need. Then reformat it and you have now gained a large portable USB drive for further back ups.
If you don't want to keep drive or it is not working I am told the best way to stop anyone from accessing it is to drill a couple of holes through the drive.
It has been shown that drives put in buckets of water, set fire to, run over by trucks could still be accessed.
Hope this helps.
Back when I was in a rifle club I had a hard drive I needed to destroy. I took it to J range on Sennybridge and shot it.
Worked for me.
Guys guys guys! You're doing it wrong!
Before you destroy the HDD with a hammer, take it apart and have a good look around, you will learn a bit about what's inside...
Then smash it with a hammer :-)
There are usually some excellent little powerfull magnets inside these things.
But yes, definetly reccomend the hammer method for data security.
That's one of the things i love about this site.
The sheer wealth of knowledge that is out there and the fact that folks are willing to share it.
Thanks folks i will have a go at your suggestions.
Possibly with the exeption of the rifle range bit.
Steve
I was asked to securely erase some hard drives from old computers at work. They seemed happy with what I did.
