DJ!
I want a trickle charger I can plug straight into my F800GS`s power socket. Any ideas?
Optimate ....just add a BMW type plug![]()
An Optimate will do you, but wire a connector direct to the battery - if you try to charge the battery via the power socket the CanBus will say nonono - unless you have the UberSpetiale BMW charger ...
G
Cheers Guys I think I`ll hold out for a BMW charger, it sounds easier for a lazy sod like me.
I have a bmw charger I want to sell if your interested.
Hello everybody,
I got bit confused from two posts. One saying...
"I am going to fit an aux socket straight off the battery with an inline fuse to charge and run my Gerbings kit from"
This is the best solution - no canbus compatibility problems.
The black plastic bit that contains the existing socket already has a hole underneath on the other side. Drill through the top and you have an ideal location for a direct fused socket.
When connecting to the battery, do one terminal at a time. Hold the main connector tight to the battery with a screwdriver, undo the nut, put on new connector and redo nut. This way you don't lose service data.
Hello everybody,
I got bit confused from two posts. One saying Optimate+BMW plug adaptor will do the job (I assume just plug&pray) and another post says that the Optimate should be connected directly to the batery otherwise the CanBus wil say nonono.
Could some of the wiser tossers explain himself and teach me a lesson so I can understand what is thew most appropriate action? My riders manual says that unsuitable charger or connecting the charger wrong way can damage the bike's electronics.
Vaclav
