Jeez you guys are anal. Dont you have anything better to do.
It's good sport!
The fact that you are a short arse and can't reach the floor properly on your GS doesn't make the Super Ten more compact
..... but then you continue to do so anyway - go and ride one and you will see what smooth low running really means, I don't mean it pulls from 2k like a GS will, a fucked washing machine vibrates less at 2000 rpm than a GS motor under load.I've not ridden the Super Ten so I can't comment
this is greatRasher said:I am 6'1 so not exactly short, yet notice the firmer feet planting on the GS is harder to achieve.
Rasher said:Bike Magazine measured the BMW at 246.7KG and the Yamaha at 264kg, if you believe the manufacturers published weights your a complete fool, although it look like Yamaha are being pretty honest and BMW are talking complete shite, the difference is 17.3 kg, less the 2.1kg for fuel = 15.2.
Rasher said:I also found an internet article where someone grabbed a load of mates bikes and put them on some weighbridge and also found similar results (i.e. BMW are not too honest about the fully fuelled weight, perhaps they mean fully fuelled with the wheels taken out, or the FD on the bench being repaired at the time)
Rasher said:..... but then you continue to do so anyway - go and ride one and you will see what smooth low running really means, I don't mean it pulls from 2k like a GS will, a fucked washing machine vibrates less at 2000 rpm than a GS motor under load.
this is great
Presumably the Yam was on the same seat height setting as your GS? You did check that didn't you? Are your GS seats higher since Tony Archer modded them?
Perhaps you could give us the link to this article, if its not too much trouble?
Still good to see you spouting more of your crap about vibration levels on the GS though. Are you sure you know how to ride a motorcycle properly?
Fairly certain, and I have ridden both and can therefore compare, you seem to be a typical "blinkered" BMW owner refusing to believe anything could be better in any conceivable way, the Tenere is massively smoother, even the "paid off"press can't lie to this degree.
I also reckon the bike will prove more reliable over time, although the blinkered BMW owners are able to somehow completely overlook EWS / FPC / FD / Cam Sensors / Fuel Gauge / RH Valve issues and claim the GS is totally reliable with no issues, whereas normal people would describe the GS' diabolical reliability record as just that.
Heres the link:
http://www.advrider.com/forums/showthread.php?t=682993&page=19
About 1/3rd of the page down
Maybe you should learn to read Rasher. According to the thread in ADVRider the difference between the GS and the Super Ten is 26kg, not the 17kg you claimed above. They weighed the GS at 242kg and the Super Ten at 268kg.
So what you are saying is when we respond to your attempt at giving us "facts" we are blinkered? Is that the best you can manage?
The (Yamaha) torque curve generally tops the rest of the machines with exception to the Ducati, and is essentially flat from 3000 to 7000 rpm before tapering off to the 8100 rpm redline. Maximum torque is 71.19 lb-ft. at 5500 revs.
“Its long, smooth power delivery is very quiet and vibration free
“It has a constant push that feels like you’re propelled by a nuclear generator.
Even though it doesn’t post massive peak numbers, the linear output and ability to stretch each gear allowed it to post the best 0-60 mph time.
Even with the most aggressive mode, the Yamaha still doesn’t cut out as much as the others and it allows enough tire spin to help steer with the rear end, which is very necessary in the dirt.
All of our riders praised the Yamaha for its behavior on the street. It refuses to be pushed off-line and it surprised all of us with its ability to carve through twisty sections
Yamaha joins BMW in offering shaft drive to the rear wheel, but the Tenere’s drivetrain is superior to the German’s. Four out of five testers ranked the Japanese drivetrain first, and the fifth had it a close second.
I’m not surprised the only Japanese bike of the bunch has the best drivetrain. Smooth and positive gear changes, no noticeable drivetrain ‘snatch’ and smooth, silent, care-free shaft drive are a plus for adventure travel
Nearly zero engine and road vibration, plush suspension, ultra stable chassis, best seat-bar-peg relationship combined with the best rider protection,” sums Riant. “Add the least wind noise and buffeting and the Yamaha is my top choice for comfort.”
The engine is a rugged performer and the drivetrain is practically flawless.
At low speed the throttle response becomes very choppy while easing along with slow traffic,” Maddox says about the BMW. “This sensation is exaggerated by the slack in the shaft drive. When the speeds pick up it’s not as noticeable, although a hard downshift will result in a chirp of the rear tire.”
- and lets be honest most GS owners put a few hundred weight of touratwat junk on their GS' anyway.Dave Riant has been to the northern and southern tips of North America on two wheels. Four decades of riding has seen him chase ISDE glory in his younger years and he’s since transitioned into dual sporting, trials riding and adventure touring. His regular travels have taken him across the U.S. and he visits Mexico every year
Our testing troupe consisted of five men, separated by up to 30 years of age and 75 pounds - dirt fiends and street lovers with over 135 years of combined riding experience
,Snipped Rasher's selective use of the road test:
I think you two should meet up over a pint i bet you will get on like a house on fire.....![]()
That would be interesting but I am sure Rasher would have reservations about going to certain pubs and drinking certain beers because he read on the internet somewhere that they cause bad flatulence.![]()
, right one last fling:They made no comment about vibration levels below 2000rpm for the GS
....In that time they have not produced a GS beater in all respects.
Finally, can you show me where I have said that I am "convinced his bike is as smooth or smoother than the Yamaha despite not have ridden one, purely based on the fact it is a BMW and therefore must be superior."
