Triumph Tiger 1200 Explorer 2015 less than 6 weeks old!
Big Derek
Blyth Notts
OK here is the Great Crystal White 2015 less than 6 weeks old
Triumph Tiger 1200 Explorer ....
2,122 MILES....
C/W
TRACTION CONTROL
The Tiger Explorer also comes with traction control as standard to give you added safety and confidence in slippery conditions. The system reassuringly keeps wheel slip to a manageable level by reading the speeds of both wheels, along with numerous engine parameters, and adjusts performance to assist the rider in maintaining a safe course.
CRUISE CONTROL
Cruise control is fitted to all Tiger Explorers, easing fatigue over long distances and optimising fuel efficiency.
SWITCHABLE ABS
The standard ABS system uses the latest technology to prevent wheel lock-up in any condition you find yourself in. And it can be switched off for off-road use to match your riding style.
950W ALTERNATOR
As a serious all-weather rider you would expect to be able to use various electrical devices, so the electrical system is powered by a class-leading 950W alternator. Plenty of power for you to use on the optional heated grips, spotlights, and seats.
IMMOBILISER
a coded key immobiliser system in case your Explorer attracts the wrong kind of attention. It disables the ignition if an attempt is made to turn or force the ignition switch without the presence of the electronically coded correct key.
INSTRUMENTS AND COMPUTER
The Tiger Explorer tells you everything you need to know on a journey. The LCD instruments use handlebar mounted thumb switches with up/down scroll facility and feature a comprehensive onboard computer including 2 trip meters displaying distance covered, journey time, average speed, average fuel consumption, instant fuel consumption, range to empty.
much more
extras include Heated Riders seat :-)
Headlight Guard
Radiator Guard
Heated Grips
OEM Panniers
Cleaned rad guard now mint NO-BUGS!
FOR-SALE....
£10,250...
CALL Derek Cumbers​00447736157500
I buy bikes and I sell bikes
Sent from Big D,s iPhone using Tapatalk
