Tuning chips etc
karlp
Southampton, England
Does anyone know if there are such products for the GSA.
I have searched power commander but nothing.
Just looking for a good system to sort out any fuelling / ignition issues.
I'm reliably informed that a Dynojet Power Commander designed for a completely different make and model of motorcycle will plug straight into the loom on the 1200. You then install a zero map and get a custom map made up on the dyno.
The slight problem is that I'm sworn to secrecy over which Power Commander will fit. The company which discovered this is trying to negotiate some sort of deal with Dynojet over it.
Thanks???
:oonyack Very Helpfull!!! Any advice on where to get a chocolate teapot or is that secret as well !!:augie
Wunderlich PC/ Power Controller made by Techlusion ... couple with freeflow can, K@N filter and :D:D:D
Received a Wunderlich catalogue from Nippy Normans today. Above controller listed along with other tuning bits. Worth giving them a try Karl
I'm getting a twin Akrapovic race system from the US and a K&N Filter too. I understand that it will make the engine run lean so it will need some sort of 'help' Is the Techlusion box above what I need? How easy is it to use? Do I have to take it to be dyno'd and setup like I did with my 'Blade and PCIII ?
Any advice greatly appreciated.
Matt
Yes I have been reading about this - looks ok just seeing what else is available.
Karl
maybe not such a secret as there is one advertised on the powercommander site for the 1200GS.
Karl
936-411 - Coming Soon!
That's good news then and at c. £170 in the US, maybe I can pick one up in California this summer.
Karl
LOL, I saw that too today for the first time. Anyone have any experience of fitting one? How easy/hard is it?
Matt
I fitted a PCII to my VFR800. Very easy to do - unplug the loom from the ECU, insert the Powercommander between the ECU and the loom, attach laptop, upload requisite map and Robert is your parent's brother.
