twin spark aftermarket EON plugs
demito
Belgium, Overijse
Read some very positive comments on the Champion EON plugs and would like to get some for my 2004 ADV as well. The plugs come in different versions (EON 1,2,3,4) and I am still not sure which one fits the twin spark engine. For the single spark 1100 or 1150 it seems to be EON 2, but Fanum states two different spark types are used in the twin spark engine.
see also: http://www.ukgser.com/forums/showthread.php?s=&threadid=38820&perpage=16&pagenumber=2
Another thing is the gap setting (should it balways be 0.95)?
Any clarification here. Which EONs to pick? :confused:
Reason for my concern is that I once had a piston ruined on a rented bike because some local indonesian guy put in the wrong plug type.
Apparently the Eon plugs are only available in one size so you cannot get a small Eon plug for your 2nd plug on your twinspark.
Is the bigger plug the same as the standard 1150 GS then (EON2)?
Any ill effects of combining an EON with a non EON?
Tnx
Demito
