*touring ted*
Hey all.
I've inherited a sickly R1150GS Twinspark. I've been asked to see if I can get it going. The bike was a good strong low mileage bike until one day it started cutting out and then it cut out for good.
There is no spark to any plug. And when I pull the injectors and crank the motor there is no spray. If I pull the fuel hose off the injectors and crank I get pumped with fuel. Definitely fuel pressure there.
1)The HES has been replaced with a new one. It tests perfectly on the bench with the LED test system. The fuel pump also fires every 180 degrees when you turn the crank. I'm confident its fine.
2)The motronic is energised. I get full dashboard and also 5V at the TPS. I've also tested the Motronic on another bike and it works perfectly. The clutch switch and side-stand switch work as they should. Neutral light works. I'm trying to start the bike in neutral with the side stand up.
3)When you turn on the key, the pump primes and the injectors are momentarily energised while the pump motor primes. This is (I think) normal as it's what happens on my friends bike. It makes sense as the injectors are powered by the fuel pump relay.
4)When you cycle the ignition and crank the engine, you occasionally get a single spark and a spray of fuel from the injectors. But just once. You have to cycle the ignition again for this to happen.
5)I've tested the main coil under the tank. I get 0.5 Ohms on the primary (Normal) but 55 Kohms on the secondary (should be 7.5 KOhms). This is out of spec and a new coil is on order, but it doesn't explain why the stick coils and the injectors don't fire.
6) When I test the voltage when cranking over, it drops to about 10V. I get the same reading on the alternator.
Question. Will the 1150 Twin spark run JUST on it's stick coils ??? I think it should.
Should the injectors only be energised momentarily or should they always have a 12v live with the ignition on ??
My guess is that the motronic is not earthing the injectors (to fire them) and not earthing the coils (to fire them). But why ?? It works on a different bike.
I have to start thinking is something sucking all the current out of the ignition system ? I think i'm correct in thinking that the bike would fire and run even with a dead alternator with a fully charged new battery.
Any ideas ??
Any ideas ??
