Twin spark - coils, position?
Santa-2512
Omnipotent one
North Pole
I get the concept of a twin spark system, and dual plugs at the top of the cylinder head,
But why the lower plug on the hex & TC units ?
I guess the lower plug is still in the compression band when the cylinder is at TDC
is it designed to fire on the exhaust stroke to get any last unburnt hydrocarbons ?
When a plug sparks the mixture does not instantly explode, a flame travels out from the spark until all the mixture is burning. Now, when we have a large cylinder, that can take a little while, so the maximum pressure on the piston takes a while to build up, and at higher rpm, the piston is far enough down to reduce the effectiveness of the "bang". (This is why we advance the ignition timing with rpm). So two plugs firing at opposite sides of the combustion chamber will set off two flames that meet in the middle, so the whole mixture is alight in half the time, getting more combustion pressure when it can do the most good. As well as the time issues above, there is also a likelihood that as the single flame front moves across the combustion chamber that the increase in pressure and temperature can cause a compression ignition in the un-burnt mixture causing knocking. Single plug boxers like the R100 I used to have were very prone to knocking/pinking, and that is probably why BMW introduced twin plug heads. A "lost spark" in the other cylinder at the end of it's exhaust stroke is only there to simplify the electrics.
The problems I had with my '04 and '08 hexheads were corrosion/delamination of the lower stick coil housings and a failed lambda probe. The secondary coils are not in a good location, a shame BMW didn't design them to sit above the head away from road salt and water.
I replaced the secondary coils with Beru items which were stainless-steel jacketed, and an NTK lambda probe. These items were from the OE suppliers to BMW for a lot less money.
If I recall my workshop induction to these on Oilheads it was more of a second flame sweep for reduced emissions rather than for power as the lower plugs would ignite After the main plugs
That is also why the twin sparks will run on lower plugs but not as well its only a degree or two but that is a degree that is lost off the BTDC
