I got a tyre inflator from Nippy Normans, which works fine with the 12v socket in my truck, but when I connect to my 1200GS, keeps cutting out. Are there any solutions to this?
I think the accessory socket has a 5 amp limit, hence why you need to replace the supplied 5 amp fuse, DAMHIK. Wouldn't want to ask 10 amps through it for a long time though.
Yep the acc socket will only let you draw about 5amps, mine did the same when I wired some foglights through a centech fuse panel which was wired through the socket, wire in a cigerette lighter socket straight to the battery, alot more useful than the BMW one anyway.
This looks like the right thing. Do you think a standard ciggy lighter, connected to the battery, would do the same thing? I live in Turkey and need to sort this out soon, if I order from the UK it would take a while for the goods to arrive.
Or with the 1200, you could put some croc clips and the connect it onto the battery if taking the seat off isn't too much faff for you? Still best to have a fuse in the system though, and make sure the clips are correctly colour coded
