Sold Ultimate Addons Mobile Phone holder bundle
adventuredon
Wandsworth, London
£31 posted UK Mainland
Used but all in GWC
extra spaces and a spare wheel clamp included
brand new waterproof poncho (unopened). Worked a treat on my iphone 13
has a tough silicon pull over web (I actually put it behind the holder and just peeled the top edges over the phone and it was tight enough.
Boxes included
some details from web:
This adjustable holder is ideal If you use more than one Smartphone or use a slim protective case, the same holder should also fit, taking away the need for dedicated holders designed bespoke to specific phone models and saving money in the long run. The holder is suitable for smart phones with dimensions of Width 50-80mm, Height 120-170mm and Depth 5-15mm.
Plate adapter
Bar mount
Ultimateaddons strong metal U-Bolt mounting attachment has a 25mm / 1" ball connector and is designed to fit a range of handlebars.
EXTENSIVE COMPATIBILITY
This attachment is suitable for a wide range of motorcycles with a handlebar diameter being under 20mm across, it does not require much space on the handlebars.
MULTIPLE CHOICES
The U-bolt kit is supplied with two different size U pieces 16-20mm / 25-32mm.
SIMPLE AND SECURE MOUNTING
This attachment can be supplied as a single handlebar clamp bolt or with Ultimateaddons 3 prong adapter with push buttons for quick and secure mounting to your scooter or motorbike.
