Just a few thoughts on the subject.................I started using Ultraseal after a series of punctures on my VFR 800 and CBF 1000. Since then I have not had a puncture until on a recent wet late night return from France.
I picked up a stone in the rear Conti Trail Attack and when examining the tyres next day I found it. I thought it was only embedded in the surface (as stones usually are) but when I dug it out the tyre splutteringly deflated. Ultraseal had obviously done what it was supposed to do.
As it was near the middle and there was still some 3mm left I took it to be mended only to find out that it could not as Ultraseal prevents a plug-patch from adhering properly. As luck would have it I had ordered a replacement pair of Trail Attacks from Busters (@£129.99) which were awaiting me on my return, so these were fitted.
I wasn't particularly upset as the original Trail Attacks had done 10,500 miles.
A couple of fellow GSers thought the Trail Attacks were a good deal so before reordering I tried the local dealer to see if we could get a comparable price for 3 sets............not a chance! So Busters supplied 3 more sets............that arrived next day.
I will continue to use Ultraseal/Puncture Safe and put up with the consequences......................on the subject of TPS I would have thought that centrifugal force would keep the stuff on the tyre and not the rim and the sensor is a sealed unit anyway.
When you remove an Ultrasealed tyre there's only a coating in the tyre anyway if you put the recommended amount in.
Duncan
Duncan
