Upper Crash Bar Question - R1200GS to R1250 GS
Hatcho
Kilcullen, Ireland
Have a question for the lovely members of our forum. Having recently acquired a '21 R1250GS, I was hoping to swap the upper crash bars from my 2016 R1200GS to the new bike. Both bikes are fitted with standard OEM BMW lower crash bars. So, has anyone successfully swapped the upper crash bars from a R1200GS to a R1250GS?
Thanks in advance for any help. If I can't get a definitive answer, I'll go ahead and see if they are compatible with the new PanzerToy. (y)
Won’t fit as far as I’m aware, there is 2 1200 versions so pretty much guaranteed they won’t from 1200 to shitcam.
Hatcho can i also point out that if your 1250 has the OEM spot lights upper crash bars will not fit as the mounting points get in the way, BUT…. some manufacturers do offer an additional bracket the relocates the lights
Cheers for the heads up Bumble-Bee. No OEM spots are fitted which is a plus as I'm not a fan. I have some shiny nice lights on the way, and they will be mounted to the new upper bars once fitted.
