Les and Michael - I think someone else did this recently. You need to phoine Garmin for the unlock code as you only get one chance. When it locks (or apparently locks) it's worth going away from the PC for half an hour to see if it recovers.
PanEuro - As Burnie says increase in tile/segment size is the real problem. In CS v6 I now have to select a large part of East Anglia just to get my home in whereas in v5 this same area was 4 tiles and I only had to select one of them.
Also new or changed roads shouldn't necessarily mean more memory. I suspect this is added detailing as you mentioned. Maybe there should be an option to reduce the amount of detail to upload to the GPS unit giving those with less memory more of a chance.
One last point the CS v5 update was better than v4 as it allowed more map area to be uploaded to the GPS unit so as far as I'm concerned v6 is a step backwards or more likely a step in the direction of the latest GPS units on the market.
For those interested theree is no direct replacement for the V - I emailed Garmin and asked.
Adam
Adam
