Think it depends on the quality of fuel used..
Said he poking hornets nest with long stick....
Sent using witchcraft
I do always use premium grade
I sometimes mix mine with diesel JJH
well said have a slight rattle can't wrong on that
well ive just done the end float and valve clearances for the first time in perhaps 6 years!
My god what a difference is made. Turbine smooth compared to before and QUIET.
Didnt take too long and while I was in there I did the oil etc too
HEre are the before and after figures... scary reading on one of them
INTAKE - before 0.05 & 0.13, supposed to be 0.15mm
EXHAUST - before 0.23 & 0.15, supposed to be 0.30mm
END FLOAT - 0.23 & 0.3, supposed to be between 0.05mm & 0.40mm (BIG variation so i went for the 0.05mm gap)
The left head intake was 0.05 but one of them was pretty much closed (the gap) so I reckon valves may have been at risk there soon!
cracking job and the endfloat was dead easy to reign in, unlike the horror stories I have heard on line![]()
Ehm You did do Endfloat "then" clearances didn't you?
Yep i did
QUESTION for you Did that 30 minutes seem unbearable and will you now "check" the clearances every service for interests sake?
next job is to replace the cam chain tensioners
mine still has the original ones in (17mm heads)
Why worry it was only a rattle which it doesn't "usually" make if you use 20/50
Because I use 10 40 semi
How much approx to get a shop to adjust the valves?
