For Sale Ventura 270 Degree Foxwing Awning + Walls
mark71
Braintree, Essex
Hi All
I am selling my 270 degree awning with sides which I have only used a couple of times and still in excellent condition and would like £495 picked up from Braintree in Essex, or I may be able to deliver dependant on where you are as I get around a bit haha.
The Ventura 270 Degree Awning is an all round incredible awning. Its strong, flexible and made from durable materials for the most extreme conditions. Our awnings are waterproof, mould proof and rot proof and has a 100% UV block out rate. The poles and spreaders are made of anodized hard structural aluminium and it will not rust. The Awning easily mounts on a set of roof bars on any 4x4, pick up or van. (fitting time 20 minutes)
🚙 COMPATIBLE with any 4x4, pick-up or Van
⏱️ SWINGS out in seconds
⚖️ LIGHTWEIGHT under 20kgs
📏 HUGE shelter
💪 DURABLE & built to last
🛠️ EASY installation with included fixing kit
🎖️ 2 YEAR extensive warranty
🇬🇧 BRITISH COMPANY, based in Epping, Essex
Comes with all fittings needed, including telescopic poles, guide ropes and pegs.
1. Colour: Grey.
2. Material: Poly Cotton Canvas- the polyurethane is impregnated with mosquito repellents.
3. Water column: 2000mm.
4. Poles: Aluminium twist lock poles.
5. Cover: heavy-duty UV stabilized, 600GSM, 500D PVC with zipper.
6. Fabric thickness: 225GSM.
These are a brilliant addition to your vehicle, and comes stored in a heavy duty PVC bag and boxed for a safe delivery.
The awning opens out from the side of your vehicle and opens out to the back, offering a huge covered 270 degree area of cover. Four vertical support legs hold the awning up, which can be tilted or lowered to allow rain to run off.
The Ventura 270 Degree Wing Awning + walls can be used on standard cars as well.
Size: 2.5m - (Defender 110, Nissan Patrol, Pajero, Land Cruiser etc.)
The Ventura 270 Degree Wing Awning is very easy to set up, swings out in seconds to full setup.
Ideal for camping, outdoor activities or expedition/overland trips travelling cross country.
Fabric:
The Ventura 270 Degree Awning is a strong but flexible structure made of tough proprietary aluminized rip-stop Poly Cotton Canvas and is polyurethane impregnated. The fabric that is 100% waterproof, breathable, UV-resistant/anti-tear and solar-reflective.
The poles and spreaders are made of anodized hard structural aluminium and will not rust. Fitting instructions are provided (fitting time 20 minutes)
1. Colour: Silver/Grey.
2. Water column: 2000mm.
3. Poles: Aluminium twist lock poles.
4. Cover: heavy-duty UV stabilized, 600GSM, 500D PVC with zipper.
5. Fabric thickness: 225GSM.
The Ventura 270 Degree Awning is a brilliant addition to your vehicle. It comes stored in a heavy duty PVC bag and very well boxed and packaged for a safe delivery.
Packing Size: 255cm*16cm*16cm
This is not to be confused for the one on their website which is just the awning without the sides, this one is the complete deal which I believe is currently £799 on their website.
Reduced to £395 as its taking up space and I want to get rid of it before I get any silly ideas
