laughingBob
Had a small problem yesterday when filling up with fuel. I turned off the ignition and removed the key, filled up and went to pay. When I got back to the bike the ignition had turned itself back on. I pressed the starter and the engined started but, I still had the key in my hand. I put the key back in the ignition and turned to the 'on' position then off and the engine stopped and the screen showed that it was going through the shutting down procedure. A few seconds later the ignition came back on it's own. Eventually I got it to shut off properly and I re-started and rode it home. Its done the same thing a few times since but, not everytime.
I phoned Wollaston's and they said they hadn't had the same fault before and said it was very strange. It's now booked in to have the ECU changed next week.
Just wondered if anyone had had anything similar.
