I've just bought a pair of Vision X Optimus long range LED spots from Adventure Spec for my 2010 1200GSA. These were supplied with a loom which was clearly designed as an entirely separate switched lighting circuit for a car, plus I've now decided I'd rather control these via the standard high beam switch rather than the supplied seperate switch.
Vision X wiring diagram is here:http://www.visionxusa.com/documents/PrimeDrive_Wiring.pdf (shows different lighting unit to the Optimus)
I'll mention straight away that wiring is largely a mystery to me, especially when it comes to canbus so I'm wondering if anyone has some clear advice on the best way to wire these into my canbus high beam circuit before I blunder onwards and completely fry various parts of my existing electics
The supplied loom has a fuse and relay (30, 85,86,87) and they have Deutsche connectors BTW.
Desperate to get these fitted ASAP whilst we've still got the dark weather !
But if I'm running the power from a canbus accessory socket do I even need a fuse, surely the canbus system should take care of any overload?
