Visor cleaning, Blue Peter special
  • Thread starter Thread starter Activmoto
Activmoto
Damp salt covered roads can cause a problem keeping your visor clean.
Take a washing machine soap dispencer cut two small holes in the side for a cable tie add a bit of wet sponge and attach to the handle bar or mirror stalk.
Is the thing holding the scouring pad that you've been scrubbing away at the bars and mirror stalk on the other handlebar?? :eek: :eek: :eek:
My trick is to use a J cloth attached to a belt key holder, the spring return type. the holder is then cabled tied to the bars. It is easy to wipe your visor and when you let go it springs back.
You nicked that idea from Mike Hailwood.
He used to do that on his race bikes.
