Water cooled riders Note* great accessory buy
team duvet
Yorkshire
Just fitted these...£95, put them on the 15mm lower option, totally transformed the ride, was comfy even more so now brilliant buy. Also comes with rubber inserts.
15 plate GSA, I am 6ft 6in seat on high.
Bought from Bykebitz :thumb2
+1. Had them on my 12R and liked them so much that I worked out how to fit them to my WC GS.
They do another, more expensive version that has variable positions (more than two).
Replacement rubbers are £8 apiece ;)
Interesting. What about the gear lever and rear brake lever positions? Can you simply adjust to suit the lower pegs?
Sea Dog, just left them in the same position, then again size 13 boots LOL
I have a pair of these, got them used but excellent condition off eBay for £36 which I thought was a bargain. Had them a month or so but not fitted yet... might have to put them on tonight! Spikes pegs are great but they've wrecked my boots (needed a new pair anyway), S o the removable rubber inserts are a great feature.
I'm really torn now between the GSA footrests, Pivot Pegz and these now.
I had the pivot pegz on my F800GS... they're not much wider or grippier than the GSA footrests and the pivot is negligible to be honest (probably bit of a gimmick, unless you ride off road and even then I don't think they give you any significant benefit). You can get plastic toppers that attach with cable ties to save your boots if you're so inclined.
I got the SW Motech for my GSA LC as they can be set a bit lower and they have easily removeable rubber toppers. They seem about as wide as the GSA ones.
