Hello and yes, I've done the overhaul already and the shaft seems to get grooves on lots of people's bikes, so I wanted to change both...
Also used double lipped SKF seals.
Antti, on closer inspection it seems like 2 bolts are obstructed, so no real way around that....
rocky burns, do I understand correctly, you can remove the propeller (impeller) from the outside and slide the seals off with the shaft in place?
How did you grab the inner seal?
If you say it's possible, this is really good advice! I'll start taking a pair of seals for longish trips as this seems like a decent roadside repair method!
