Re Long Way Round: a.f.a.i.k. it was the welding: they had disconnected only one of the battery leads, not both.
that's what they said in the program.
i spoke to one of the techs on the trip and as AA posted above, he said it was a connector not done up.
T
They are the tool of last resort.
he does have an opinion on absolutly everything it seems he cant help but post on every thread
They also melted some of the wiring.
But back to removing the gearbox plug... easi out in a soft ali plug, you're having a laugh, a very big laugh
Keep it simple, very simple.
I have two sets of torq bits. Both have specific jobs. One set is used for their intended purpose of undoing torq fixings.
The other set is used for forced removal of seized allen bolts (and seized torq bolts, just hit the next size up into the damaged hole).
Here's one i removed earlier from an 1100 gearbox.
Same method works on the 1200 gearbox.
Well I would give a big thumbs up for Bendy,
He may know nothing about mechanicking, he may give shit advice at the drop of a hat, he may favour easy outs, which were clearly named that just for the laugh, but he is a top bloke![]()
Way over fucking complicated ! Thin Disk Angle grind a slot and feck'n big flat screw driver. Done it and it works fine.
Feck'n drilling holes.... FFS
correct just another one on here offering advice but quite clearly hasn't done itcouldn't use an angle grinder as the plug is flush with the casing.
