Well Well Well?
DrFarkoff
Grumpy Ole Git!!!
Islandmagee, Co Antrim NI
Now here's a good one!
2004 bike pretty much mint except the front casing
BUT cannot get the driveshaft to release
I've never come across one like this before
No pivot bar No upper torque arm and it just sits there! WTF ???
Maybe a clue a load of water and it's not rained here for ???? days
Out with a struggle but how the heck will I get the bugger off now
Tyre lever
After a good spray of wd40 I would insert a tyre lever into the UJ and lever against the end of the input shaft. It should just slide off easily.
Getting the front coupling back onto the gearbox output shaft can be interesting! You're best to push the rubber boot away from the gearbox and insert. Finger or two to lift the coupling to align it, if you don't you could be there for hours.
Are you sure that that's water in the swinging arm? If the oil seal fails on the final drive that's where it pools.
Check out the UJs as well. The shaft looks mighty 'straight'. It's not seized up is it?
Roger.
I am going to do it the easy way and lift the swingarm out bugger that trying to be a gynocologist!
Roger.
you can always just pull it to bits
check the gearbox seal rear
and dont use wd40 on uj
as it will dry out the uj
then it goes bang
snap and you have been spouted :D
check inside the hole in f/d clean any rust and repaint
like so
Is that Bilko's bike still in bits? :confused:
Duckspeed, when you quote cut out the links for the images then we don't get all the photies posted multiple times.:thumb Unless of course they are fine examples of female anatomy when more is definitely better!
If the pic's are of Bilco's bike, very likely, they are a few weeks old.
Exactly the same problem as I had with my 07 GSA. NOG had to replace the lot under the extended warranty when they couldn't get it apart. :)
