fayeslane
Mentioned this method a few times but actually remembered to take some pics today. Look -no dust
What you need:
sodium bicarbonate
cheap sand blasting gun with small nozzle
compressor set at 100psi or higher
Drum is optional but contains the spray and recycles some too.
I agitate the solution by rocking the drum as I'm working.
Isn't abrasive enough to give you a new surface like bead blasting but is a gentle clean. Had thought of adding a detergent to the brew for extra cleaning power. I sprayed this carb with degreaser first.
What you need:
sodium bicarbonate
