What a plonker
divanmostert
London, England
Hi guys,
This morning I had to jump my bike due to the damn autocom sucking it dry. When I attached the leads to the battery it made a funny beeping noise - almost like sounding the horn - then to my horror, I looked at the car battery and realised I have the leads the wrong way round :blast
I swopped them around and the tried again and luckily the bike fired up.
Does anyone know if I would have damage anything by doing this or do the system allow for stupid mistakes like this?
I would think that if she starts up and runs OK, and all digital readouts are working fine then you've got away with it ... plonker ;)
Why would the Autocom suck it dry? :confused:
I have one fitted to my 1150 and it has no drain if the ignition is off :nenau
Don't know - I reported my flat battery issue here a while back and the Autocom seems to be the culprit.
I connected it off the aux socket, so in theory it switch off after a few seconds after the ignition has been turned off. Some guys said the fitted an extra switch in order to make sure the Autocom does not keep drawing current. I should also mention that I have a bluetooth dongle attached, which could also be the culprit.
Wow that could of been expensive, add a kill switch to your kit & wire it direct to battery?
<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/Krn953AdudY?fs=1&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Krn953AdudY?fs=1&hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
I work in the car industry and we test for reverse voltage, exactly to ensure nothing major happens if you connect the battery around the wrong way.
That said is always a worrying time when you finally connect the power supplier up the wrong way round and switch it on..
Plonker! :)
Autocom CLAIM their unit switches off if the master headset is disconnected, but I know from experience that it does not. Three different bikes have suffered a flat battery after fitting autocom units, so now I always have a switch in the power line. You could simply run it through a relay switched from the headlamp if you didn't want an extra manual switch in the system...
I used to work in IT. Have fried more than one motherboard (the power connectors were easy to get the wrong way round), and more than one PC because *someone* didn't check the voltage selector switch (before the auto switching PSU days).
If it's easy to do then it's going to be done.
