Bails
I can't understand the weight increase being quoted? 256 kgs for 2018 GSA 283 kgs for 1250 GSA. Where is all the extra fat?
Think you've got that wrong mate....
Taken from a quick google search:
That means the basic GS's curb weight, complete with a full tank of fuel, rises from 244kg to 249kg, while the R1250GS Adventure is upped from 263kg to 268kg, again with fuel (its larger 30 litre tank – compared to 20 litres for the normal GS – accounts for much of the increase over the non-Adventure version).
You’ve also got that wrong. The increase in weight between the GS and GSA has nothing to do with fuel. As your own post says - there is a fundamental difference of 19kg in static weight between both models, fully fueled or empty.
The original 12gs non abs model was 199 kg. Dry. That was their target. JJH
I loved mine. It was probably the biggest jump I experienced in handling and performance since I went from a Honda 175 to a air cooled rd 250 in about 1978. JJHYes, I remember the story that the design team was given a full 30L water canister and told that was the weight that had to come out of the 1150GS for the new 1200GS. I bought a 1200GS in Riyadh in 2005, and had a n 1150GS in Dublin as well. I liked the 1150GS loads but the 1200GS felt and handled better in all ways.
It’s the increase in shock thickness to take the weight of all the old fat bastards buying them
Jokes aside, the OP ask about weight increase between 1200 GSA and 1250 GSA. The difference,official numbers says it's up from 263 to 268.
The weight increase is due to heavier cam system (shift cam weights more) and the beefed up camchain.
As for the difference between GS and GSA: If you strip down both bikes they are basically the same bike. Slightly different spring travel and slightly different steering angle makes no difference on the scale.
The GSA has a larger, aluminum tank vs the GS plastic tank. GSA has a larger windscreen, and it comes stock with crash bars and luggage rack for alu.-cases. Since 80% full fueltank is part of the given weight, the 50% larger fuel capacity of the GSA ads to the scale. Also, the alu. rims weights less than the spoked wheels of the GSA.
