Bugbear
...... when you're pushing the little rubber bung back in the flywheel timing hole
You push it right through into the clutch housing, where it falls to the bottom and sits harmlessly until such time you split the transmission and engine to change your clutch / grease the splines / insert other maintenance task here, and retrieve it?
You push it right through into the clutch housing, where it falls to the bottom and sits harmlessly until such time you split the transmission and engine to change your clutch / grease the splines / insert other maintenance task here, and retrieve all of them?
I had a few drinks at a party last year and swallowed a LED light that was inside a balloon, battery and all. Never found it again!
I inspected every poo for 3 months! Had terrible gut trouble for the first 3 weeks. Kept another one beside the tv to see how long the light stayed lit - 6 months!
My mate did the same thing at the same time, it was a dare. He never found his.
Did toy with the idea of a colonic but decided to maintain my arse as a one way valve!
