wheel compatability
cookie
Stay Frosty
Failed State
i have a 2000 1150 GS with ABS. are the wheels from an ABS GSA a straight swap? are all the ABS rings etc. the same.
more details on the GSA wheels, year etc. hopefully to follow.
edit: they are not GSA at all but "1100/1150GS wheels with the earlier, (there were only two types), ABS rings"
so i think they're the one's i want
Dunno if it helps but I bought MiGSels wheels off him and he used them on his GSA with ABS and they fitted straight onto my non ABS 1100 without a problem.
ir fitting ADV or later wheels ( i.e. servo wheels) to early bikes, you have to use the later ABS ring as well
aye , basically there are 2 types of abs ring
pre servo and post servo , all the bikes share a common part no. across the hole range
did some research on it at baldies , well ady did , before i swapped the wheels on my gs over
