Wheel offset?
Dogbytes
Helston, Cornwall
BMW R80 ST, rear wheel.
Are these laced centrally or is there an offset?
If there is an offset, what is it?
Dont no but The r100gs has none and The r100r has 5mm it cant ne hard to check just hold a baten to The side of your tyrr and measure it to The center of your hub each side then You will find aut !!!!
Well that would work if I was about to take the wheel apart - but I'm trying to put it together!:D
The 3 stud on my G/S is central , but like the R100R / GS you could probably pull it over 5 mm if you wanted to fit a wider rear tire or a aftermarket shock - a 120 hits my Ohllins .
Thanks for that.
I'm going to use a Wilbers 633 and a 130 back tyre - so moving it over might be worth doing. I'll make a decision today as Terry the wheel-builder is poised, spokes in hand, awaiting my decision!
5mm offset it will be.
FYI I called the suspension supplier today and he measured a Wilbers 633 spring for me - they're 80mm diameter, apparently. That's 10mm bigger than the standard one that's on there at the moment.
