Wheel rim weights - adhesive residue
Kamba
Member
Northamptonshire
Have any of you folks come across a good method or magic potion for removing the sticky foam residue left on your rims after a tyre change. Just had mine done and re balanced, which involved replacing some balance weights.
Don't want to damage the paint with thinners or such but I want to get the residue off and it's stuck like shit to a blanket!
Any advice/ideas please.
Google de-solv-it sticky stuff remover, then buy it from Rymans, The Range or your local equivalent.
Alan R
Another option is WD40 - not as good but you will have it in the shed
Works fine, soak a cloth with a bit WD40, dab the adhesive and let it work for a couple of minutes, gentle rub
I've just this minute cleaned my two with white spirit and a brass shoe brush.
Unleaded petrol on a rag
Job done
Petrol head to boot
Nobody wants to know about your love plums, as squeaky clean as they might be.
Very amusing!
I got new rubber fitted and the tyre fitter wasn't impressed with how greasy my rims were for him fitting balancing weights.
Came home, de-greased them both and cleaned them up then waxed and polished!
Not perfect but pretty bloody good!
When the rims are clean, polish them up with Mr Sheen. It brings sparkles to the bodywork, mirrors and tank, too.
WD40 and scrape with a credit card or fingernail.
Finish with brake cleaner.
Angle grinder and elbow grease, or petrol
White spirit, soft cloth and elbow grease does the job well enough.
Thanks for all the input. I must add that the motivation for my OP was because I ended up removing the paint on the wheel rim of a previous bike using brake cleaner, admittedly I can't recall the brand - maybe Carplan from Euro car parts?
Anyway, the De solv it and WD 40 with fingernails, credit cards and elbow grease will be employed and I will report back.
Thanks again for all the advice.
