For Sale Wheel set for Husqvarna 701/KTM 690
cookie
Stay Frosty
Failed State
I've sold my 701 so no longer need my "off road" wheel set.
Bike was a 2019 model and AFAIK these wheels fit most, if not all 701/690 Enduro models. If you’re interested, you should check for sure for your particular bike
Pair of 21/18” wheels complete with sprocket and sprocket carrier, both brake discs and ABS rings.
Fitted sprocket is 48T, stock is 46, so nicely lowers the gearing for trail riding.
Fitted with low mile Michelin Tracker tyres and Tubliss “tubeless” system for low and easily variable pressure use.
Located in Dorset £550.
Interested, but not sure these will fit my 2012 MY Enduro R. Can you let me know hub widths and axle diameter?
Ta.
Front:
26mm
127mm wide measured from outer edge of wheel bush to wheel bush.
Pretty sure nearly all KTM front wheels are interchangeable except the big twins.
Rear:
25mm
184mm best as I can measure from outer edge of sprocket side bush to the edge of wheel casting on disc side. I never had a second bush for that side, just swapped it over as unlike the others, it just falls out.
2019 hub part number is 7531001004491 sprocket support is 7501005004491. 2012 hub seems to be 7651000104430 and sprocket support same 7501005004491.
There’s a slightly different lacing pattern on the older wheels which would explain the different part nos. I’ll continue via PM …
