Wheels.
richh
Leeds.
Seems to be a shortage of front wheels around for GS's.
Was contemplating getting a new rim and having mine rebuilt.
Looks like a very simple construction to me, but my local wheel guy doesn't touch them. And it seems a few more don't like BMW wheels either.
Has anyone any recommendations for decent wheel builders in the Yorkshire region that will work on BMW stuff.
Doug Richardson seems a good egg, but he's a long way away. And it'd be nice to drop off and pick up if possible.
Cheers.
Would be a great help if you said for which model ..
I’ve a few kicking around for the 1150
Water cooled model.
So 2013 1200 right up to the last of the 1250's (2023 / 2024?)
Cheers.
The main reason wheel builder don’t like x spoke wheels,
Corroded spokes.
If the spokes are proper stuck it can take hours just to strip them apart.
No one wants to pay £300 just to get them in bits
The other thing with x spokes,
You can build them like conventional wheels but it’s hard to tru them up.
It’s better to have a jig to hold the hub and rim solid.
Then build and torque the spokes.
This requires a lot of non payback investment on each and every different spec wheel.
We had a set of wheels from a customer,
Been rebuilt/anodised/ new spokes, etc
Way too much runout.
Asked him for the original offset measurement so we could turn up the correct spec spacers etc ,
No joy,
Original wheel builder hadn’t even measured the rim offset.
Thanks for the explanation. (y)
Cheers.
There’s a few on eBay
Not many.
I’ve bought a few of them. Stocked up.
Seen my arse with the spokes. Too many issues I’ve seen while researching the wheels.
Loads where the spokes are pulling through the edge of the rim. Corrosion in same place.
Going back to the cast. A little bit lighter too.
Gonna get a pair powder coated to suit my rallye.
Got one of my "new" wheels in the post.
Looks like the TPMS sensor bolt is snapped in the wheel?
More work. Is it a heat and easy out tool sort of a job?
