Where do you buy your DRZ400 parts from?
squid
north staffs
My local dealer wasn't much help at all - to say the least.
Where online to get general service parts from. I want a gasket for each side case and expect I'll need one to check the valve clearances.
And I've failed miserably to get an extended mixture screw in the UK.
Leisure Trail in Long Eaton (Notts) is another option. Pretty good for technical info too; once you get used to the piss taking :D
Whenever I have to buy from a dealer I try to go armed with a part number.
This site is handy for sourcing part numbers & cross referancing them with other bikes, i.e. lots of DRZ parts are identical to RM parts.
I was recently looking for a lower chain guide rubber & couldn't find any on eBay - searching the number on this site showed it was also used on the RM250.
eBay had a guide rubber listed for the RM250.
Here's the site..
http://www.ronayers.com/
..click on fiche.
Thanks for the links
I see Wemoto only list a full gasket set not separates?
Parts I want are.
Extended mixture screw (can't find a place to order from)
48 Pilot jet (Allens performance have these though)
gen side case gasket (ebay seller does for £14 though)
Going to locktite the nut on the otherside so might need that gasket too
Pivotpegz (nobody as yet seems to have any in the UK - can get from europe but they are £25 more)
Thinking of a comfort seat too.
Thinking of a high performance battery?
Do you need a new seal when checking the valve gaps?
I have bar risers fitted but I'm also going to fit some Renthal Enduro high bars (been on order for two weeks now!) Might be tight with the throttle cable length.
