Switching the ignition on properly before spending days checking all the electrics for a fault......
Refittng the neutral light wire, that obviously wasn't on properly, after you have just refitted the gearbox, driveshaft and bevel box![]()
re-fitting the M6 nuts that hold the rocker covers on, especially the front one, RHS if you have crash bars![]()
Yes, and what about the 8mm screws holding the airbox/gearbox on. Especially the one that hides right under the air intake.
This thread could go on forever ! ('scuse the pun)
getting the garage airlines to fit the valves especially the rear wheel and even better with panniers fitted.. I kinow ... the cranked extention makes it easier![]()
Defo the rubber gaiter on the gearbox/drive shaft ( mono) ,the clips aren't much better either.![]()
i worked out a way to do that.
let the driveshaft rest on the bottom of the paralever casing, with the splines angled up. bring the bevel box down on it from an angle, and straighten up as it engages.
works every time for me![]()
What about replacing the entire wiring loom?
Weather was bad today so decided to tackle this task. The original wiring look on the 80/7 had been hacked about with and looked like the wiring had been done by a lobster.
I bought a new loom from Ebay which was like new for a mere £10.
Might take me a while to get everything connected back properly. Routing the cables is fun too.
If it all goes tits up, it will be a project at next years Airhead weekend although I would really like to get it sorted over the winter months.
Going to set it up as unfaired to start with, then have the option of fitting either an RT or RS fairing.![]()
... and looked like the wiring had been done by a lobster.![]()
still giggling here ~ i just love that for a description!Getting the driveshaft to mate with the final drive on a paralever.![]()
Found this awkward too......Oh, and on the R90 (I'm sure it's the same with a number of others) refitting the long bolt through the air filter housing. Frustrates the heck out of me at times.
