Which size Battery
  • Thread starter Thread starter beakmeister
beakmeister said:
Any tips, cos I now have the Tank off and the Battery tray out :thumb
Make sure you get the routing of the cables correct otherwise you won't be able to adjust them properly.
Getting the cables back on the throttle bodies is tricky, you have to do it by feel and instinct. I'd reccomend getting them back in place and the cable correctly seated in the V of the pulley before putting the adjuster on. You will need to balance the throttle bodies after doing this (I did it by ear as I've not got a working manometer).
Mike O's got an excellent guide to this with instructions and pictures on the board here. Have a look for my post about idle being high as there's the link to that on it.
