Why do KTM Pistons Wear Out in less than 150 Hours?
Magwych
La Salvetat Peyrales, Aveyron, FRANCE
There seems to be a general view that the single cylinder KTMs need a new piston every 150 hours or less, why is this?
As well renowned manufacturer I was gob-smacked when I learnt that I have to keep replacing a major engine compenent in my 250 EXC-F after relatively short usage. The general feelign seems to be that if you ignore this the engine would self-destruct :eek: This is not limited to just the 250 EXC-F DOHC engine
Do they have fundamental flaws in the lubrication system, or is it the materials used for the piston/cylinder? If it is the latter then surely there must be someone that make a more resilient piston? I love the bike, but am now concerned about the engine's fragility.
Is there anything that can be done, or is this just part of the KTM kudos?
I think you will find that most of the racing four-strokes made by any of the manufacturers have the same dire warnings in their owners manuals. If it's any consolation to you, my Honda CRF 250x has similar "service intervals", and it's still on its original piston, rings, valves etc.
If it bothers you that much, trade it for a DRZ.
Mark
In order, the keys to decent engine life are (IMHO):
  • gentle-ish warm up
  • oil quality
  • filter changes
  • use of high revs
Here's the rationale:
  • Engines are designed to be used at their operating temperatures. When cold, clearances between moving parts are mostly wrong and the oil doesn't circulate so well. Wear occurs quite quickly. So warm the engine up by making it do some work (not just left to idle) but don't work it hard until it's fully warm
  • lubrication comes from the long-chain molecules in the oil. When oil is old these molecules break down. Fully synth is better than mineral for holding these molecules together, but whatever you use, change it regularly.
  • A dirty oil filter impedes flow through the filter and can force open the bypass mechanism (often the spring that holds the filter's seal against its mating surface). The circulation of dirty oil is an obvious cause of wear. Wet-plate clutches cause oil contamination too, so filter and oil changes are very important. A poor quality air filter will allow the ingestion of dust and grit.
  • At high revs loads are usually higher so the wear rate is higher
My 2d
Greg
I think you will find these specs are for a raced bike.
There is a big difference in terms of wear on a motor from an A-racer wringing the neck of the bike round an enduro course and your average trail rider bimbling along ....
Ahh, raced bike? not me. Average trail rider out bimbling = me.
I tend to treat all vehicles as Greg says, they last a lot longer that way :rob
It seems a lot of users opn KTM forums are either racers, or like to think of themselves as racers :augie
If I ever upgrade to a 'Berg FE390 I will factor in a new piston wghen outing the 250EXC-F to maximise the happiness for potential new buyers...
What the others all said....
My KTM isn't ridden with the engine working continously at high RPM in competition conditions hence I just service it regularly with quality synth oil and new filters. It doesn't rattle, knock or burn oil so I have no intention of tearing down the engine to see why its working sweetly.
