Troppo
Bemused observer
My post from another thread:
I have owned many large bikes, including a Blackbird, a FJR, a Busa, a ZX14 and a B-King, and the mighty RT outhandles and outbrakes them all.
I have never, in my 40 years on two wheels, ridden a touring bike that handles so well in the twisties, and yet is stable as a rock on the highway.
I also own a new GS, and it is interesting to compare the two:
The engines feel very different - yes, the RT is still tight, but the heavier flywheel is very noticeable - the RT is very smooth, and the GS is more raw and urgent.
The extra weight of the RT is obviously noticeable, particularly at a stop and in the garage.
Wind protection is (obviously) in a different league. The RT puts you in a calm bubble. Mind you, the GS is pretty good, but nowhere near the RT.
The RT is pulling about 3300 RPM at 100 km/hr, and the GS donk is revving about 800 RPM higher for the same speed.
The GS will happily pull 4th around town, but the higher gearing of the RT means that it tends to be happier in 3rd...mind you, I am avoiding lugging the RT engine.
The GPS integration on the GS is MUCH BETTER than the RT. The GS beautifully integrates the bike's ECU with the GPS, so you can display all the bike's parameters on a customisable GPS screen. The RT does not offer any of that....on a bike costing much more...
AND, Herr BMW, why can't I lock the GPS on the RT mount like I can on the GS?!
The RT quickshifter works really well, particularly 4-5-6, as the ratios are closer together. The auto-blip-on-downshift is a neat feature, and a lot of fun...although I still like to go down the box manually.
The menus are simple to use, and I like the radio.
It was surreal descending the Gillies Range (280 corners in 19 km, 3000 feet elevation change) with Pink Floyd's Comfortably Numb blasting away as the horizon rolled left and right...
The engine modes are noticeably different, as with the GS. Dynamic mode makes the bike quite spirited.
It is easy to see why the journos rave about the 14 RTWC. Wonderful.
