Why is Acronis partition recovery so bloody slow!!!!
Fanum
Toubab
Secure unit 2
:spitfire
For some reason I got a dose of spyware......tbon.exe.
Adaware didn't pick it up, Spybot S&D didn't see it and MS Windows defender didn't notice it either...good old ZA picked it up when tbon asked for access.....
Anyway, I started pissing about in the registry to root the bugger out and found some other stuff I didn't like, so I'm reverting to a mirror of my C drive from a couple of days ago that I know is clean.
FFS though.......It's ben running an hour and it's still got another 5 to go!!!
I could have reloaded winders from scratch after a full reformat, applied my last files and settings backup (I do all sorts of backups these days) and had it running with everything reinstalled in half that time. :spitfire
I can't see why it's so slow.....I wouldn't have bloody started if I'd known :(
that's odd. just done one & it took 13 minutes, and i thought that was a bit long :nenau
:eek: This was from a USB2 HDD to the boot drive.....I did use compresion but not the highest level :nenau
It took a similar amount of time to make the image but I just left that running at night so it doesn't matter .
Odd ...and annoying :(
i've restored a few drives from acronis, but never from an external drive. maybe that's got something to do with it?
It took my machine about 80mins to restore C: with an Acronis backup, it was just a basic XP setup too, I thought that was slow, but it did it ok :nenau
It's got to be the USB drive...I let acronis make a recovery partition yesterday and that process only took 10 mins......I need to look into it deeper but I can't see any way of updating that image ??:nenau
If I stipulate an incremental backup, I was expecting it to give me the option of updating the image in that hidden partition but it doesn't :(
(Or I could reclaom the 250gb USB HDD for other use)
that's odd as well. maybe it's because it's hidden :nenau
what i do is make a backup image to another internal HDD partition, then copy that image over to external drive.
Hmm.....
It seems odd though doesn't it...the hidden partition is a mirror of the boot drive...it means you can hit f11 on boot up and it'll copy the hidden 'c' to the actual C for fast recovery.
There seems little point in it though if you have to go through the palaver of recreating the hidden partition each time :nenau
I'll have another poke at it :)
My backups are getting silly anyway....I've got a files and settings one at well over 100gig and mirror copies of my C and files drive at 162 gig......plus now I've got an 85 gig hidden partition on the main SATA drive.
WTF!!!
:rolleyes:
Fanum said:
Hmm.....
you don't need to do that with acronis. if you can access windows you can initiate a boot & restore from there. if windows is inaccessible, you boot from the acronis rescue disc & do it from that.
you won't need the mirror anyway as you will have the acronis image :nenau
i admit pressing one key on boot is a bit easier, but how often do you need to do it?
Acronis will be slow if there is a problem with the disk
acronis true image server is a lot faster
I dont have a problem from imaging from usb drives or from the network
(are you sure its usb2)
I always make the c partition as small as possible and move my documents to another drive
how big is the partition?
