Wilbers shock Yellow spring
Valker
midlands
I want to change the black spring on my Wilber shock for a Yellow one, anyone know where I can get such item.
If I can't get a yellow spring, would it be better the powder coat or re-spray the black spring.... would powder coating crack?:augie
i sprayed a WP spring with aerosol Plasti-Kote from B & Q. lasted for years :)
powder coat, the heat wont harm it, coated mine on loads of bikes,,, checked with NB coatings in ponte,
a lot of after market springs are coated...
Cookie, I went down to B&Q today to get myself a tin of Yellow Plasti-kote, they had Red,Green, White, Brown and Black but no feckin YELLOW, so I went to there super store, they just had White, not very super Mr B&Q:nenau
Just a pointer on spring making and powdercoating.
Springs are generally made from spring stock , which is supplied in a known temper.
After coiling /grinding ends , ect, they are annealed by heating to 300c , and any powdercoating takes place during this annealing process.
So it is wrong to automatically assume that they can be heated againg without changing them in some way.
It probably wornt make them unservicable, but they wont be the same as before you started either.
Yellow springs are the best springs you can get.
They are so much better than black, although i hear purple ones are almost as good.
I wish my spring was yellow, they are so much more springier.
I think the yellow pigment has some sort of elastic properties............ :mmmm
mine are purple and they work just fine is it really worth the effort??:nenau
Oh shit, mine is white and my fork springs have no paint at all :(:(:( :D
shock powder coat
Thanks for the powder coat tip job completed £7:thumb:thumb:thumb:beerjug:
I DIDNT WANT THE SAME YELLOW!
